Hi guys,
I am very new to antenna/satellite installation. We got rid of Dish Network a while back (over a year ago) and have since been using a cheap nonamplified indoor antenna. Our reception is pretty spotty, particularly when it's overcast outside so I'm looking to install a roof top antenna and wire it into the preinstalled coaxial cable through our home. Here is the antenna I'm looking to purchase LINK
We live in a three story townhouse (about 20 miles North of Atlanta) so since I will be using approximately 30-40 ft of wiring to connect the antenna to the near-ground "inputs" I've read that I should use a signal amplifier. I've also heard of a pre-amplifier installed right next to the antenna - but don't know which is which, to get both, or are they essentially the same thing? Here's a link of the pre-amp I've been looking at LINK
My last question is I have two coaxial "inputs" and a grounding wire near the ground level of my house. I assume one of the coaxial "inputs" receives the signal from the antenna, but what do I need to do with the 2nd "input"? And since the ground "inputs" are already grounded do I need to ground closer to the antenna?
Here's a photo of the preexisting wiring outside (ground level) that our satellite dish was connected to. Do I need to split the line coming from the antenna into these?
I apologize for my dumb questions! TIA
Craig
Craig
