AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Need advice on attaching black velvet to wall.
Need advice on attaching black velvet to wall. - Page 2
post #31 of 34
With all the wonderful advice that I received from you guys I did what you told me to do. I made the panels and wrapped them with the velvet and it came out great! Here is a pic of how it turned out.
post #32 of 34
Nice job!
EDIT:   Get a stand for that center channel though! wink.gif
Edited by jkasanic - 2/3/13 at 9:29am
post #33 of 34
Originally Posted by Pain Infliction View Post
Ok. My wall is already black so i don't need to worry about that. When you guys are talking about a snug press fit, I am assuming that the screen is the center piece that all the frames are pressed against and the ceiling and adjacent walls are the other points? If so, than that is way easier than expected. Maybe I can fill each panal with some sound dampening material to help accoustically?? Is that a good idea or scratch that?
post #34 of 34
Here are shots of velvet stapled directly to the drywall. The wall is 12' wide and the upper edge is 1/4 birch ply I had leftover.with fabric stapled to the back and then brad nailed to the wall. The velvet was then stapled on the sides and where the screen would hide it. Second strip was done the same way and stapled where the base trim would hide it and around the outlets for my powered speakers.
Edited by design1stcode2nd - 2/7/13 at 2:33pm
