AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Total nontechy needs recommendation for used commercial projector
post #1 of 4
I know completely nothing regarding projectors but what I read online. I have a nightclub I really need a projector to play videos on but have a very limited budget. What should I be looking for and can anyone recommend the best place to look for used and refurbished so I can get the most for what I can spend? New is out of the question right now.
post #2 of 4
http://www.avsforum.com/f/218/display-devices for classified ads here, there is a viewsonic pro8200 there for $650, it would be bright but have some limited placement restrictions. Hard to suggest if we don't know how "limited" the budget is.
post #3 of 4
Thank you. That is a better price than I thought I would find. My budget is limited to "probably can't afford to get what I need". Was hoping to stay under $500 but doubted it was possible.
post #4 of 4
I have found a Panasonic LCD PT-LB50U, new in the box for 500.00. Would this work?
