AVS › AVS Forum › HDTV › HDTV Technical › digital combination of HDTV signals?
post #1 of 4
does anyone make an external antenna combination device? after all, HDTV is all digital. so why not sample 2 to 30 different antennas to determine the best guess at what the individual bits are?.
this might even change the current art of guessing antennas into something that is less sensitive.
post #2 of 4
The radio waves haven't changed. The laws of physics haven't changed. Only the transmitted data is different. The transmission method is the same as its always been.
post #3 of 4
Antennas don't care what is on the carrier, they just care about the carrier. If it'll pick up a signal, that's all it cares about. In my area, I can literally put up a coat hanger and get most of my local channels, including full 1080i.
post #4 of 4
It's possible to do what you asked if you can afford it. You need 2 to 30 different HDTV receivers, all tuned to the same RF channel and a processor to do m-out-of-n processing of the outputs in real time to determine which of the eight levels is being transmitted and output the corresponding 3-bits.
  Back to Forum: HDTV Technical
