AVS › AVS Forum › Audio › Speakers › Energy veritas v5.2's on my new homemade stands
post #1 of 28
I got them in a week ago and they wouldnt fit in the tv stand so built custom stands !! Cost 28.00 smile.gif and going to add one piece of wood to the back of them to screw them to the back of the tv stand !! Also haven't taken the klipsch off yet!! [IMG][IMG]
Edited by benca1 - 1/20/13 at 8:42pm
post #2 of 28
post #3 of 28
post #4 of 28
These things kill the klipsch gallery series in every way possible.!!! No comparison at all !!!
post #5 of 28
But, eh, aren't you afraid the little person in the one picture will be poking tweeters and drivers with the grills off? I know my son would have (lol).
post #6 of 28
Lol my 2 year old doesnt bother them at all!! Never bothers electronics!!! I have a velodyne it sounds great !! Is it bad ?
post #7 of 28
tell me about it biggrin.gif around 3 between RC and VERITAS my daughter poke 2 energy rc and a visit 1 veritas.
Edited by losservatore - 1/20/13 at 9:56pm
post #8 of 28
Sub recommendations ?? It's a vx-11!!! What should I look for ??
post #9 of 28
I used to have the VX-10, which I understand is very similar.
Get a 12" sub from Internet sub manufacturers SVS Sound, HSU Research, Outlaw Audio, or Rythmik. They all make amazing subs that are far better than what you can buy at the stores, sometimes even for twice the price. Any of their 12" subs would be just as big (if not more) an upgrade as your V5.2s are over your Klipsch for movie watching.
post #10 of 28
post #11 of 28
Originally Posted by losservatore View Post
I've written that list so many times now (well, except Epik used to be on it) that I forget about the new "old" kid on the block. Yeah. Add Power Sound Audio to that list. biggrin.gif
post #12 of 28
Very nice stands.
I'm surprised no one mentioned this but I would really recommend you re-arrange the front 3 speakers.....a lot.
Diffraction is the 1st thing that comes to mind when I look at your setup.
Try to position the center at least even with the edge of the stand and see if you can move the fronts apart more and further up.
Ideally, you want to form an arc with the 2 fronts spread apart as far as you are away from them. Do what you can.
I think there will be a big improvement in sound after you're finished.
post #13 of 28
Yosh!! I can move the center fwd but as of right now I can't move the fronts out further !! I want to bad but can't right now !! Just had another baby and brought home this week!! So now have swings, pack and play and other stuff in the way frown.gif plus with them being as big as they are really no where else to put them anyway but like 2 ft further out frown.gif
post #14 of 28
I hear you. i Have a baby boy that's very curious about this things, that's why i keep my grills on. Very nice stands by the way. Great setup. What are you using for surrounds?
post #15 of 28
post #16 of 28
Move the speakers forward so they're even with the edge of your entertainment center. That would make a big improvement. If you cant get them wider apart at least this move will help.
post #17 of 28
post #18 of 28
And thank u a ton afrogt for the code on these smile.gif I love these speakers more than any I have ever had ( even though the gloss black are dust magnets )
post #19 of 28
I'd love to hear your setup. I have V5.1s in a 2.1 setup, and Veritas VS Surrounds in my HT setup (Energy RCs for the front sound stage). As good as they sound, I've wanted to hear those V5.2s.
post #20 of 28
I want to upgrade receiver so bad now! I have Yamaha 473!!! I want a marantz bad !!
post #21 of 28
Just ran the mic and since I hooked them up so fast with the new baby home I had the center out of phase lol !! Fixed it and now everything is great smile.gif
post #22 of 28
Ran ypao and this is the levels it gave me !! Will move the sub up for sure to around -1 or 0 but the speaker levels don't seem right at all!! I keep having to change the l/r back to small as it tries to set them to large even though they are the same speakers !!
post #23 of 28
Most room correction software sets speakers to large if it thinks they can be run OK without a sub, and then you have to override it.
You should turn the gain (volume) down on the back of the sub and rerun YPAO. That -10 means YPAO thinks you have it turned up much more than you need to. It's setting the speakers as positive numbers to try to help offset that balance. So adjust it down and try again.
post #24 of 28
U want me to adjust the gain to what like 10% ? Right now the gain on the sub is like 40% !! Then rerun ?
post #25 of 28
Why is center so damn low compared to l/r? Wouldn't I want to hear my center more ??
post #26 of 28
Reran using sub on 15% have me these settings and another pic to follow !!
post #27 of 28
post #28 of 28
Set the sub at 15% gain!! Have the speakers set to small .... sub is on +1.0 and center is +2.0 with right front at +0.5 and left front at +1.5 as I sit more right of center so now I have a field of sound ( within reason as they are close together ) and the crossover is on 80 hz on the avr ! Sub is wide open on crossover using the avr to do it smile.gif
  Back to Forum: Speakers
