Hi,
I just recently purchased a sc-1227-k reciever and I'm having a few issues I need some help fixing. I have my reciever connected through an Ethernet connection directly to my wireless router.
The problem I'm having is that when I try and connect to my pc through the 'net' feature the reciever just shows the wps access point but doesn't show the pc, it appears to just lockup. If I turn off the receiver then turn it right back on the wps connection shows the pc and I can now browse it. Why won't it connect without powering off the unit?
2nd problem is if I connect the sub to the main sub out port and run the automatic speaker config on the 5.1 setup, it doesn't recognize the sub. I have to plug it into the sub zone1 outpu then it works. But I plan on hooking up the 3 zones and I won't be able to if I'm connecting the sub to zone 1 and the main sub out doesn't work.
Can someone help me with this?
in their setups.
