Originally Posted by
Bond 007
Thank you. Can you give me a practical example of when someone might have 2 things running at once on a tablet? Maybe if you had 2 browser windows open at the same time?
That would be an example. So would having two different apps running at once. Example: downloading a large PDF (using the browser) while also checking mail using the Mail app. But even the operating system is also usually doing
something in the background so having multiple cores, if properly implemented, lets things run more "smoothly" from the user's perspective. Apps and windows open and close quickly, browsers scroll smoothly, etc...
Bond 007
In general would a dual core be better at playing video since its faster?
Yes, no, and maybe. It all depends on the performance of the CPUs and the complexity of the video stream being decoded. Also, most current tables offload much of the video decoding to the GPU (graphics processing unit; on a PC you'd call it the "graphics card") so it would also depend upon the capabilities of the GPU and the video formats that are supported on a hardware level.
But
very generally speaking, faster multiple core processors (i.e. more expensive) are also paired with better GPU's. This can often be measured by supported video formats and/or resolutions. For example, a HD 1080p video stream (1920x1080), when displayed, has about SIX times as many pixels as a standard definition (720x480) video stream. A performance limited tablet may play SD just fine but then struggle with HD.
Edited by bluechunks - 1/21/13 at 11:03am
