This is absolutely geeky, I know, but I play call of duty and I place a small piece of painters tape in the middle of the screen right where my red dot/aimer/sights are. I use it as a point of reference when i'm looking at something so i'm always not too far off when I go to aim. Anyways, I just switched from lcd to a used 46pz80u and when the pixels move around for the anti retention pixel orbiter feature, it makes me have to follow it around the screen with the piece of tape. I noticed i had my input label set to game and that made the pixel orbiter stuck in "automatic". i just switched it to cable and now i can change it to "force" and pick a number between 1-4. Basically what I'm curious about is, is there a way to fully shut it up? If not, what is the way to make it happen least? I'm wonder if force 1 will make it just rotate all around the dot ever minute and keep it close? or force 4 might make it happen less? in auto it'd sometimes end up at least an 1/8th inch away from the centre tape. it didn't seem to move in a pattern of any sort. I did a bunch of searching and can't seem to get a full break down on exactly what the orbiter does down to which way it'll shift and I also can't seem to find any way to turn it off. I got the TV for 100 bucks, so not too worried about any burn in
AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Can I turn off pixel oriber on Viera (for good? reason).
AVS Top Picks
