So I'm finished framing and about to start running my low voltage runs and conduit for future proofing.
Is there an established best practice for bringing conduit (in my case, 1.25" carlon smurf) into the theater?
I'd like to run conduit to several locations:
Stage
Riser
Projector (though this technically won't be in the theater so I don't need to worry about it so much)
Side Surround locations (will be behind columns)
Rear Surround locations (will be behind columns)
Do I simply terminate the conduit in a low voltage box and cut a whole through the drywall or just bring the conduit through the drywall itself? I normally would try to have the conduit enter the theater where a soffit would be placed, but I'm not sure if I'm going to add soffits yet (due to headroom) so I'd rather not lock myself in.
Edited by memmo - 1/21/13 at 10:11am
Stage
Riser
