AVS › AVS Forum › Audio › Home Theater In A Box › Problem with 770 playing Bluray
post #1 of 4
Inserted Bluray disk and player says "cannot read. please check disk." I insert a dvd and it plays as normal. I have cleaned the heads using a Memorex Bluray Lens cleaner. I have updated the firmware. All the Blurays I buy are from Bestbuy or Walmart, so the region code should be correct. Am I missing something?
post #2 of 4
What is a 770?
post #3 of 4
A Sony BDP-S770 maybe?
post #4 of 4
you have defective disc so if it is new take it back and ask for a replacement it does happen i had one and the replacement worked or your player has gone south
  Back to Forum: Home Theater In A Box
