AVS › AVS Forum › Audio › Receivers, Amps, and Processors › DENON AVR2112Ci Wireless help! How to get setup for AIRPLAY!
post #1 of 6
Hey Guys,
I am running a Denon AVR2112Ci and two Definitive Technology floor speakers.
I recently moved my internet router to a different room, so now I can't directly plug the Denon receiver into the router.
I am exploring options for wireless adapters, but not sure whether it needs to be a ethernet capable adapter, or if I can use a USB adapter.
Any insight or help would be much appreciated... I am just starting out so any help would be great!
post #2 of 6
http://www.iogear.com/product/GWU627/
I was told this is my best option?
post #3 of 6
post #4 of 6
Much appreciated.
Any color on whether the TRENDNET Wireless Bridge or the Apple AIRPORT Express?
If I primarily use apple products (ipad, iphone, airmac), is the Airport Express better applicable?
post #5 of 6
Either should work equally well, although AE may have easier time with Airplay.
post #6 of 6
Thanks for input!
