Did some more reading, and the List of Reference Level, High Sensitivity & SPL Speakers answered a lot of questions about terms I've been seeing in posts but not undersanding e.g. what is this 'reference level' you speak of? Also found out that the sensitivity ratings given by manufacturers aren't necessarily standardized e.g. the HB-1 Mk2 rating of 92db is a 'half space' measurement, which means that it was taken while the speaker was up against a wall instead instead of a straight up anechoic chamber. The author of that thread therefore considers its true sensitivity to be 3db lower, hence 89db. Anyhow, according to his calculations, a pair of HB-1 MK2s need 267watts total to reach 105db at a distance of 12 feet. The FS52s and s30s, with lower sensitivity (?) and lower max power ratings (130w and 100w respectively, vs HB-1 MK2's 250), do not appear to be able to reach reference level at 12ft. Not very important for music, but it might be a consideration home theaterwise.
That's that I thought initially, but the '+Main' ends up being superfluous unless you have the fronts set to large per batpig's quote.
Edited by Resonate - 2/2/13 at 6:34am
Originally Posted by Louquid
LFE+Main sends bass frequencies below your crossover point to your sub. Music doesn't have an LFE channel, so it would essentially have no bass if you have your front's set to small and sub set to LFE only. The +Main portion allows bass where an LFE track isn't available.
(Prodigy's 'Spitfire' is a good example).
Thanks for all your guys' help. Some more notes:
