AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Help with outdoor speaker installation
post #1 of 5
Hi guys
My current setup consists of a yamaha RX-A1020 with 7.1, then I have two outdoor speakers connected to a small Panasonic stereo. What I would like to do is have the outdoor speakers connected via zone 2 on the Yammy. The problem is I have a two storey house with concrete slab in between levels 1-2, so I'm unsure on how to run the cable from the amp to outside.
Is there any wireless speakers that I could connect to the zone 2 on the amp?
Any help is appreciated
Cheers
Edited by Johninperth - 1/21/13 at 10:07pm
post #2 of 5
There are wireless audio send/receive units - but what are you trying to get from your AVR? Radio, set-top box output, music library? Take a look at using a Sonos unit for the outdoor speakers instead - you'd get control of it from a wireless device as well...
post #3 of 5
I want the radio, cd, iPod etc to play outside. Isn't the sonos units standalone?
post #4 of 5
No, the Connect unit attaches to any stereo receiver. Although a Sonos Connect:amp unit might be a better overall solution...
But for wireless connections, there are several available:
http://www.meritline.com/wireless-rca-video-audio-transmitter-receiver-1w---p-70239.aspx?source=fghdac&gclid=CM6NgaWq-7QCFQ45nAod6EsA3g
Jeff
post #5 of 5
Thank you for your help
  Back to Forum: Home A/V Distribution
