AVS › AVS Forum › Audio › DIY Speakers and Subs › Stereo Integrity Dual 18"
Stereo Integrity Dual 18" - Page 2
post #31 of 112
Was too cold tonight to do grills, but tomorrow I will definitely have them done.
post #32 of 112
F*ck yeah.
post #33 of 112
What are the plans for finishing the plywood edges?
post #34 of 112
Like it is. On the next set i can give my hand at mitering, but adds to time which adds to cost. I honestly don't mind it as i've been wanting to do a translam for a long time now....:-D
post #35 of 112
Originally Posted by bhazard View Post
F*ck yeah.
post #36 of 112
That is bootymus.
post #37 of 112
Grill boards cutout even though it's about 40 deg outside. tongue.gif 'Bout to workout, then wrap the grills and install magnets!!! I hope you like the styling I did on the grills. cool.gif
Also.....Vincent..... This thing is JUST going to make the shipping Fedex Ground limits. biggrin.gif I have to be crazy careful on the double boxing. I might take the feet off and let you put them back on that's how close this is going to be. biggrin.gif
post #38 of 112
UPS ground limit is 165lbs or so. The box is pushing 165? damn
post #39 of 112
Dimensions also come into play with items this large.
post #40 of 112
Yeah, it's dimensions, not weight. I think it weighs about 80 - 90 lbs. It'll be about 165 when it's loaded. biggrin.gifbiggrin.gifbiggrin.gif
post #41 of 112
Well......drum roll.....Hope you like the grill.....
Time to do magnets and done!
post #42 of 112
Yep, just like we talked about. Totally unique, sexy, and badass all at the same time. Just an awesome job all around.
The magnets are most important, because other wise when I flick my beer caps at the grill, they would no longer stick like they would with the SubM. You have no idea how useful this is with people over. lol
post #43 of 112
Wait.....so you want magnets on the outside too????:-P
post #44 of 112
No no. lol Usually the magnets on the inside of the grill hold around 10 bottlecaps when you toss them at the grill. Don't ask how I found this out.
post #45 of 112
Well...disappointing news. The magnets aren't holding the grills in place. I'm going to shop around for stronger ones. If I can't, I'll have to put more on the cab but I didn't want to ruin the appearance with 8 magnets on each baffle.
Will update asap.
post #46 of 112
K...found some...ordered. Should be here mid week. If these don't hold...........we'll figure it out. biggrin.gif
post #47 of 112
So close to completion. Totally worth it.
post #48 of 112
Just had an idea...
The shape of the grill makes it interchangeable. It could technically be used top to middle, or bottom to middle. It should totally be utilized.
Do the magnets require one set to be permanently on the wood? I think it would be cool to pick and choose how to mount the grill at will. I'm debating in my head if it would look ugly to have extra magnets on the top if i wanted to mount it top to bottom.
Sent from my Nexus 4 using Tapatalk 2
post #49 of 112
Issue is that the magnets are recessed in. Meaning I have already bored into the finish. rolleyes.gif That is definitely a SICK idea. We keep thinking of things after the fact. tongue.gif The magnets I ordered are a black chrome color, so would be a bit more hidden. It's your sub, your call. wink.gif
post #50 of 112
LOL, the whole thing has been made after the fact, but it hasn't failed us yet. Yeah, do it up and add it in the cost. It would definitely be cool.
post #51 of 112
Magnets left Philly two days ago....They better show soon.
post #52 of 112
Joey - are you using neo magnets? I've used both 3/8 and 1/2 inch with tons of holding power.
post #53 of 112
Are those depth or diameter? I tried with 1/8" thick x 1/2" diameter. Not even close to keeping it up and there isn't much more for me to take off the grill......
I ordered a different brand so hopefully they are much better.
post #54 of 112
I really think you're simply dealing with polarity issues. The grill on my AVH-15 build uses neo magnets on one side and simply metal disks on the other. Zero problem with it holding. If you can remove the magnets from the grill, try attaching them directly to the ones on the cab first. Then score them with a marker on the visible side, and install them back on the grill with the marked side down.
post #55 of 112
3/8 and 1/2 was the diameter. Both were/are 0.2" deep/thickness. The 1/2" guys want to take my fingers off when I put the grill on, haha. Double check the polarity, these neo magnets are STRONG. I use 4 magnets per grill/baffle and recess mine into the baffle and paint over them.
post #56 of 112
I do check the magnets exactly as you say, and then recheck when I put the grill on that everyone snaps to place.
Link me the ones that you use. I just purchased some N52's.
I know they are strong, that is why I don't understand why they aren't holding up the damn grill!! tongue.gif
These are what I just purchased -
https://www.kjmagnetics.com/proddetail.asp?prod=D82B-N52
post #57 of 112
for magnets i used these
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=320-016
holding power through some Gorilla Glue seepage/bondo and duratex is pretty insane
post #58 of 112
post #59 of 112
I think the thickness has a large part to do with it. I think the ones I am using are too thin. They are maybe 1/16"? Definitely under an 1/8".
Sibuna, where are you in WNY?
post #60 of 112
south of Rochester
