AVS › AVS Forum › Audio › Speakers › Recommendations for sub and avr for PSB
post #1 of 2
I am getting ready to buy the psb w1 wall mounted speakers for my 15x15 HT set up. Looking for a sub and AVR. I heard some subs/avr go we'll with some manufacturers. Need 5.1 and 2 zones. Budget 1-1.5k. Need airplay, network connections on avr. If I change to monitor audio, would you recommend anything else,
post #2 of 2
Not really...with the exception that you want to make sure the AV receiver you buy has enough power for the speakers...the purchases are really separate.
The sub is moderately dependent on your speakers (how low can they get)...but highly dependent on the size if the room.
  Back to Forum: Speakers
