Is it OK to build recessed light backer boxes from OSB+drywall, or is OSB+cement board necessary for fire safety?
I'm using the 4" remodel cans from Lowe's (the ones that come with a housing and white baffle for ~$16), non IC, but have a thermal cutoff switch. There are no real guidelines in the product documentation about clearances between the housing and any other materials- just 3" min from insulation.
