Originally Posted by aznbladez
I tested with a kill a watt and it came out to about 51 watt with nothing being played. Wattage does not increase when volume is turned up or down. It increases only 3-5 watt with something being played at medium level and around 10 when something is on loud.
It isn't that bad but still substantial. Another reason I made this thread is because I'm thinking of upgrading to Floorstanding Paradigm Monitor or even the studios and I may have to get a separate amp ( most likely an Emotiva) for that.
Yes, that is 36 kWh per month 24x7 ;)You add a separate amp, a beefy one, and I am sure that will double at least.
