Have had the BDP-103 for 4 days. I have legacy equipment so I am using a different setup. For sound I am using the 5.1 multichannel outputs of the oppo to the 5.1 multichannel inputs of my receiver and the optical output of the oppo to the optical input of my receiver. For video the oppo is connected directly to my tv via an hdmi-dvi cable. I am also connecting an at&t uverse box. The hdmi of the uverse box is connected to the hdmi input on the back of the oppo. In order to hear 5.1 digital dolby from the uverse I am using the optical out to the receiver. I am using all monoprice top of the line cables. The picture is beautiful, the oppo definetly improves the att picture. The problem is the sound. The digital dolby seems to go on and off where there is no sound and then it comes on again. I have the settings in the uverse to surround, if I change it to stereo the problem goes away but now I have no 5.1 sound. I played a cd using the optical out of the oppo and it was fine. I also have analogue outputs from the uverse box directly to the tv and there is no problem. I have the optical out set at bitstream. Any suggestions not sure if the problem is with uverse or the oppo.
Thank you.
Ed
Thank you.
Ed
