I finally got my 60" GT50 delivered. It looks great. During the installation process, we ran into some problems getting the TV to sit flush on the existing mount. It turns out, the power plug was running into the wall mount. As we were taking the TV off the wall, the optical cable snagged and broke the port on the bottom of the TV. Now the optical cable will not stay in place. The port still works (it is currently taped) and sounds fine. Does anyone know what would be required to replace the port?
