AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Airplay Help
Airplay Help
post #1 of 4
Downloaded the Airplay software from Marantz yesterday. Worked perfectly. However later that evening my Iphone couldn't find my receiver? Do I need to have the Marantz set to anything special?
post #2 of 4
This happens to me occasionally when using Spotify with my ipod. I have to unplug the receiver for a bit and plug it back in. Works after that. I've also found that if I exit the Net/ USB on the receiver before closing Spotify it doesn't happen. Hopefully that works for you. I have the SR7005 by the way.
post #3 of 4
thanks I'll try that. Question, will I lose my settings on my Marantz if i unplug it?
post #4 of 4
No. The settings will remain unchanged.
