AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon AVR 1513 vs. H/K AVR700
post #1 of 9
Hello everyone,
I recently bought a Yamaha RX-V371BL that crapped out on me after 1 hour of usage. After trouble shooting the issues, I gave up and returned it to Amazon. So, having said this, I'm looking for a new receiver in the next few days. I only need it to use the built in 5.1 ceiling speakers that I have in the place that I currently live in. There's a few that are currently on sale at best buy:
http://www.bestbuy.ca/en-CA/product/harman-kardon-harman-kardon-5-1-channel-3d-av-receiver-avr700-avr700/10216597.aspx?path=6891a824fcdf57c6454c13fb589cae8ben02
http://www.bestbuy.ca/en-CA/product/denon-denon-5-1-channel-3d-home-theatre-receiver-avr-1513-avr-1513/10199397.aspx?path=39b4362b020c943ea01ca47ec597bb73en02
Which one is better of the two?
I'm on a budget with regards to buying a receiver for around $250 and under.
Edited by forevergone - 1/22/13 at 8:05am
post #2 of 9
You might want to consider the Onkyo 515 or 616.
post #3 of 9
Thank you for the suggestions.
I'm on a budget with regards to buying a receiver for around $250 and under. I'm a beginner to home theatre systems so I think the 515 or the 616 is out of my league for the time being. Any comments with regards to the two I linked?
post #4 of 9
Well, I still recommend Onkyo. I think Amazon has the TX-NR414 for $230.
post #5 of 9
Thanks, I'll take a look. I'm located in Canada though. No comments on any of those 2 receivers linked?
post #6 of 9
The 1513 is probably the better of the two, but I think the Onkyo has more features and better performance at a comparable price.
post #7 of 9
I don't think I've ever seen a review of the HK AVR 700.
Lots out there about the 1700 but crickets on the 700.
post #8 of 9
so stay away from the avr 700?
post #9 of 9
One more receiver to consider is Pioneer VSX-1022K, lot of features and lot of user feedback in this forum. If I hadn't gone with the HK AVR-1700, I would have gone for the pioneer as well. I also returned the RX-v371BL to amazon after hearing how wimpy it sounds (of course it was was the bottom of the barrel model for yamaha).
