I am building some boxes for my front speakers and decided to use a pre-fabbed baffle (mainly to try something different) which has a routed lip around the entire perimeter (11/32" wide by 15/32" deep area removed along the outer perimeter of the baffle). This requires a recessed "channel" to be routed along the inner edge of the front face of the speaker box so the baffle fits properly. The picture below shows the type of cut I need to rout into the front face of the speaker box. The red dotted line represents the outer edge of the recessed cutout area I need to make in the speaker box. I have not assembled the panels yet, fyi.
How do I get 90* corners to match the sharp 90* corners of the baffles? Obviously the router bit will leave the corners rounded. The problem is only with the top and bottom panels - the side panel cuts are straightforward based on how I am assembling the cabinet. I could do 45* bevel cuts for the corners of the top, bottom and side panels but would rather not go that route.
Another option would be to slightly round over the corners of the baffle.
