AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › UMass College Dorms 802.11x secure, can't connect to xbox live.
post #1 of 4
Alright so I've been on about 10 different forums including xbox and xbox live chat, and nothing has helped me. My problem is I live in a dorm that requires registration of mac address, once you do that you can't connect to xbox live because it doesn't support WPA2 Enterprise, so im stuck.
I've also tried to bridge my macbook, and xbox with no success spent about 10 hours doing this as well.
Any help would be appreciated.
post #2 of 4
you'd have to look up how to bridge your mac book and xbox. the school can't control if you're using the mac book as the access point. the easiest way is to use a crossover ethernet cable between the machines and internet connection sharing in Windows.
post #3 of 4
Are you able to get something like this where you live?
http://www.windmobile.ca/en/pages/data-plans.aspx
post #4 of 4
Buy a router that supports WPA2 enterprise, plug in the RADIUS info and provide them with the new mac address and/or spoof your existing one?
  Back to Forum: Xbox Area
