AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › What Hook Up Am I Missing?
post #1 of 2
I have my LG hooked in my Marantz as well as my Apple TV. All good coming the mu 5.1 surround system. However when i watch one of the LG apps(i.e. you tube) I can only get audio from the TV, not the surround. Am I missing a audio connection? thx
post #2 of 2
You need to have an optical connection from the tv to the Marantz. That way, if you use the internal ATSC tuner you can listen to discrete 5.1 audio (tv) via the Marantz. Also, if any of the smart apps support 5.1 audio, you should be able to hear that thru the Marantz as well. Turn off the tv speakers.
