Im on approximately the same budget as you, after doing mounds of research i settled on the FH-6t for towers $250 pair, and the FH6-LCR for the center $100, PL-200 sub for $250 or the F12 for 200 (1000w vs 500w) from BIC America. I too was interested in the primus, but got the BIC anyway even if they were on sale If you look around theyre rated higher than many other popular brands, even ones way out of their price range but cost much less and for some reason are using the same speakers as the Acoustec line of their brand, so its a great deal. check amazon for them and the primus's too thats the best price, or acoustic sound design where you can name your price, thats how i got mine.
Center (similar specs for the towers):
Design: All lacquer 3-way 250-watt 6 1/2" Kevlar LCR speaker w/vertical and horizontal wall mounts
Frequency Response: 42Hz - 20kHz
Sensitivity: 90dB @ 1 watt, 1 meter
Drivers: Dual 6 1/2" Premium Grade Kevlar woofers, 2 1/2" Premium Grade Kevlar midrange, 1" liquid-cooled titanium tweeter
Magnetic Shielding: YES
Gold-Plated Terminals:YES
Recommended Power: 10-250 watts per channel
Impedance: 8 ohms
Dimensions: 8"H x 23 1/2"W x 6"D
Weight: 17 lbs. (7.7 kg.) each
Warranty: 5 Years Parts & Labor
BIC ranks very well compared to their price point, usually being the lowest of any speaker they're pitted against. my $0.02
go to amazon, youtube, or the owners thread on here
KO
Edited by Knight Operator - 1/26/13 at 11:24pm
