I am converting a screen capture video to wmv. There are two options, Video 9 and Video 9 Screen.
now, each resulting wmv video is the same frame size, same fps, and same kbps, but the resulting files are of a vastly different size; the "screen" wmv is like a third of the size.
My understanding was that the kbps, multiplied by the duration, gave you total file size, and that the visual quality really depends on how many fps and how much motion you tried to cram into each second.
but here I have same video, length, and kbps and the file sizes are different. I can only assume that the "screen" version actually dips far below the target kbps when it can. right? and that the kbps I selected is only a "maximum" threshold?
