Originally Posted by shiboboo
This thread got me thinking about a possible solution to an annoying problem I've encountered: I cannot get my ps3 to connect wirelessly, but wired it's just fine.
I've tried manual set up with assigning the ps3 a static ip. I've turned off the router firewall as well as the wpa2 psk of the ssid. I've tried a combination of things, but nothing has worked.
I have an Asus rt-ac66u, so I have separate 5ghz ac and 2.4ghz networks set up. I have an Engenius ESR9850 N router currently sitting unused which boasts a "range extender" feature. What I'm looking to do is have the Asus maintain it's position in the network as the main router and have the Engenius sit downstairs by the ps3 and pick up the 2.4ghz N network wirelessly. I don't want a separate N network with a different ssid, as the Asus' network signal strength is good enough throughout my house. My only end goal for this is to plug the ps3 into the Engenius to hopefully trick the ps3 into thinking it's truly a wired connection, and thus work. This should be feasible, correct?
Well, you really need to give more information. Basically, you're want to use the Engnenious as a repeater or a bridge, wihich is WiFi or wired connection respoective, to the main router.
Where does PS3 fail in connecting to the ASUS. It's possible, the PS3 does not play nice with the ASUS. Does the PS3 even see the SSID on the ASUS; I'm assuming you're broadcast is set to be seen. Have tried manually entering the SSID and passphrase? The static IP would be something you need for portforwading or DMZ because you're not getting a NAT2.
