I might make the plunge. I have always put it off since I don't like the idea of flagged stations. It make little sense to me to record or save something I probably can not play back in the future. I change my PC and OS and SSD drives often enough that it makes this an issue for me. I don't anticipate changing that at all.
But I am learning that many stations are not flagged. So if I recorded a local station show- I could still play back that series for later enjoyment even if I built a new PC since then. Correct ???
I'd love some insight on how flagging works and the limitations of using your HTPC as DVR.
I'd also love some advice on what card or tuner is best.
I have my eye on the HD PRIME or the CETON. Anything better or worse with one ??
My HTPC is a 3570k on Asrock Z77 motherboard and 8GB DDR3 1600mhz. I have plenty of cooling and room in my ANTEC300 case for a card.
But I also have a gigabit switch with spare ports on my server.
Thoughts? Advice?
(thanks in advance for intelligent reply!)
Thoughts? Advice?
