AVS › AVS Forum › Video Components › Home Theater Computers › Peerless HDS-WHDI100
post #1 of 2
Anybody using one of these and, if so, what do you think of it?
http://www.youtube.com/watch?v=-EQEfLph8L0
My wife an I just bought a Sharp 70" tv and, quite coincidentally, a Dell windows 8 desktop PC that has an internal BD Rom drive and, consequently, OEM PDVD 10.
Rather than buy a bluray player, I'd like to use the PC as an HTPC and use the above WiHD system's transmitter to transmit an HD signal to the system's receiver at the TV. One of the apparent advantages of the above system is that it has an HDMI passthrough port. This will allow our present Sharp 32" 1080p monitor/TV to display what the big TV displays, which could be advantageous.
Obviously, I'd like to know if the system actually works before buying it and would appreciate any input from users of this sytem. (Our TV is no more than 20 feet from the TV and there will be no walls between the transmitter and receiver.)
post #2 of 2
Herve,
This is Justin with Peerless-AV. Based on your setup the HDS-WHDI100 should work great. The transmitter has 2x HDMI inputs, 1x HDMI passthrough and the receiver has 1x HDMI out and a mini USB HID input. This system has been extremely popular and the feedback I am getting from customers has been very positive. If you have any questions about the HDS-WHDI100 or any of our other wireless systems please feel free to contact me.
Justin Holtzman
AV Integration Specialist
jholtzman@peerless-av.com
Tel 800.865.2112 ext242
Fx 800.359.6500
http://www.peerless-av.com/
