AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Which sub should I get?
post #1 of 14
I live in a apartment so I want to go with a small sub. The speakers I purchased are nht super zero 2.0s
So should I get the matching sub?
http://www.crutchfield.com/p_228SUPER8/NHT-Super-8.html?search=nht
Or could I get this save some money and be about the same?
http://www.crutchfield.com/S-OUsYctSIUOO/p_653S8B/Mirage-OMNI-S8.html?tp=187
Or do you guys have another option?
post #2 of 14
Do you want a small sub for the small footprint (size of the unit) or do you think a small sub will bother your neighbors less? Personally I'd get a bigger sub like the Klipsch RW12D, especially when on sale for $300 shipped from newegg as happens frequently. Just don't turn it up as much.
ps there's little value to "matching" subs. It's about frequency response, extension and spl.
post #3 of 14
Ditto.
post #4 of 14
If you need a small sub, go for the Hsu STF1 over either of those, it is about the same price. If you want deeper bass and can handle a somewhat larger sub, look at the Hsu STF2. If you want a sub that will get loud, go for the Klipsch RW-12d, if it is on sale.
post #5 of 14
Having a small foot print isn't all that important it was mostly not wanting to be the `menace` neighbor but hadn't really considered that I could just turn it down. Sorry this is my first set up outside of a sound bar, shadyj what makes that sub better? Its certainly in my price range. Thanks again for your help guys smile.gif
post #6 of 14
I think the STF subs will dig a bit deeper in bass, the STF2 especially. Their larger cabinet ought to make them a bit more efficient down low, they have more powerful amps, they have longer warranties. The Klipsch sub ought to get a lot louder than any of these, right now it is in stock at newegg.com for $350 and free shipping. Anyway, in the face of these better choices I would definitely skip the Mirage and NHT subs.
post #7 of 14
Not sure about level but am pretty sure the Klipsch will exceed the Hsu 10" offerings and extend much lower, to 20hz fairly reliably. At $300 the Klipsch is a very good deal (and goes there regularly shipped), and even at $350 is worthy of consideration.
post #8 of 14
Thanks shadyj I'm going with the Hsu STF1 seems to be a phenomenal value according to what I've been reading really appreciate the help.
post #9 of 14
I agree, the Klipsch might be able to dig deeper, but I think it is tuned higher than 20 hz, so I doubt it is getting down to that point. I think its chief advantage is its output, not its extension.
post #10 of 14
I don't know what it's tuned for, but was going on Archaea's measurements. I haven't actually measured mine yet. I was also remembering only the STF1's spec at 32hz, not the 25hz stated by Hsu on the STF2.
post #11 of 14
post #12 of 14
Neither the stf1 or 2 as a larger cabinet than the rw. Neither one has a more powerful amp either. Just from listening I would say the rw goes every bit as low as the stf2 and is a lot louder. I had an stf2 and returned it for an rw. I would rather have one rw than 2 stf1s.
post #13 of 14
I think shadyj was comparing the HSUs to the NHT and Mirage subs while commenting that the Klipsch will have the most overall output for the money.
post #14 of 14
I see. I re read the whole thread and that makes sense.
