Doing my 5.1 or 7.1 setup and looking for advice.
After reading many threads here, I pulled the trigger on a Denon AVR-1913 refurbished. Seemed like too good a deal to pass up at $379. Also grabbed a pair of the Polk RC60i in-ceiling speakers from Newegg. Those aren't going to set the world on fire, but at $69 for the pair, I thought they'd be a good start, and I can always upgrade later.
Now I need to make a decision on the rest of my speaker set up. Options I'm considering now are the following:
(1) Polk Blackstone TL3 front, center and right paired with either a Polk Psw111 ($499) or Psw125 sub ($550)
(2) Polk Blackstone TL2 5 pack (front, center, right and surrounds) paired with either a Polk Psw111 ($499) or Psw125 sub ($550)
(3) Energy Take Classic 5.1 package ($399)
I had originally thought about just doing 5.1, but, of course, now that I went with the 7.1 channel Denon, I'm tempted to go with a 7.1 set up. If I did that, the easiest set up for me would be to use the extra two channels as front height surrounds. I think that would mean I'd have front, center, right speakers mounted at the same elevation just under and to the sides of the TV and then "height" front and right speakers mounted on the same wall but near the ceiling. Does that make sense? Is that the right set up, and is it worth doing?
If so, I could swing that with the TL2s or the Energy Takes and still be within budget, which is about $1k for the whole system ($600 or so left for speakers after Denon and in-ceiling purchase).
If not, maybe it makes more sense to go with the more expensive TL3s and stick with 5.1.
Thoughts?
And thanks!
Thoughts?
And thanks!
