I was going to go this weekend to best buy and get the 55" panasonic st50. I just called and they said they had one left, if the tv sells before i get there this weekend which tv would you recommend i have been without a dam tv too long now so i am getting SOMETHING no matter what haha. Thanks price range is around the st50 which is $1299. thanks
AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › which tv should i get if i cant get the st50
AVS Top Picks
post #2 of 18
1/23/13 at 10:13am
post #4 of 18
1/23/13 at 10:19am
post #6 of 18
1/23/13 at 10:37am
post #7 of 18
1/23/13 at 1:00pm
post #8 of 18
1/23/13 at 1:54pm
post #9 of 18
1/23/13 at 2:01pm
post #10 of 18
1/23/13 at 2:32pm
post #11 of 18
1/23/13 at 2:46pm
post #13 of 18
1/23/13 at 3:07pm
post #15 of 18
1/23/13 at 3:34pm
post #17 of 18
1/28/13 at 10:07am
post #18 of 18
1/28/13 at 10:29am
AVS Top Picks
I will say that the ST is "Best bang for the buck". One particular reason I chose my 60GT50 over an ST(not even a high-tech reason) was based off the cheesy plastic bezel that would reflect a bunch in my home on the ST. This is only my 2 pennies
they would have to order it i just called and asked how many they had. should i get another brand plasma
