I want to order some cables for the subs I'll be building and not sure how I'll need to wire everything so would appreciate some guidance. I have an EP4000 and BFD I intend to use. From what I've seen, sounds like I'll run a cable from the AVR to the BFD, then cable from BFD to the AMP, and then wires from amp to the DIY subs. If I run the signal into the amp's 1/4" Input 1, would I run a cable from the amp's XLR Input 1 to XLR Input 2 in order to use both channels on the amp?...Or do I need to Y split the cable and send the signal into the amp's Input 1 and 2. Here's a diagram of what I'm thinking?
Related question, could I use the BFD to EQ all 4 subs if I use one channel for the DIY 18s and another channel for the Epiks?...Just Y split the signal from the BFD to the Epiks?
