AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Should I use THX or SMPTE viewing distance guidelines?
post #1 of 4
Hello
I currently have a 51 inch plasma display and am sitting 6.3 feet away from it, I followed SMPTEs guideline there, but is one better than the other?
I am the only one that will really be using this HT room.
myhometheater.homestead.com/viewingdistancecalculator.html
post #2 of 4
I was looking at that before, and I read that you should be 2.5 times the height of the tv from the tv itself.
post #3 of 4
no one is watching you, sit where you want.
post #4 of 4
+1
