AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer MCACC question
post #1 of 4
New to this MCACC stuff and don't quite understand all of its functions. When using this feature, are the settings stored for using Acous.EQ mode? If i were to change any of the settings, what would be the need to have the EQ mode on?
Thank:)s
post #2 of 4
If you change the acoustical EQ settings you modified them from what the auto setup set them at. You still need EQ mode on to use your modified settings it's just a modified EQ. If you turn off MCACC then you've turned off all EQ settings even if you modified them. I recommended you spend time this thread http://www.avsforum.com/t/1112470/official-pioneer-mcacc-thread/0_50 . It's dedicated to MCACC and there are some very knowledgeable people in there who answer question pretty quick.
post #3 of 4
post #4 of 4
Anytime Jeep. The guys in the other thread are really great.
