AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › At what price point are cd players overpriced and not worth it
At what price point are cd players overpriced and not worth it - Page 2
post #31 of 73
Originally Posted by keyboardcat View Post
Speaking of the same audio quality with flack are blank cdr the same way? Even the cheaper brand cdr like memorix maybe? It will sound the same as the regular cd?
Most people burn their audio CDs on whatever they have, and it works out just fine.
If you burn CDRs on a stand alone audio CD recorder, you are forced to burn at 1X which may cause difficulties with common CDR's that are designed for burning at high speeds.
post #32 of 73
jd and Arny would I be able to tell much of a difference with this over my older jvc and technics cd player? http://www.hideflifestyle.com/all-products/music-hall-cd15-2-cd-player.html
Even though my fisher cd player is old, I think that it sounds pretty good. what about the http://www.hideflifestyle.com/all-products/nad-c515bee-cd-player.html
or http://www.hideflifestyle.com/all-products/nad-c545bee-cd-player.html
I doubt you'd hear make much of a difference between the old and new CD decks, if any. Anytime a previously mass market item like a standalone CD player becomes more niche, the better the old stuff is compared to the new at a given price point, and often the next-gen cheap stuff will be just as good, if not better, than both. Standalone CD players are getting to be specialty items, so the lower volume means they cost more per item than a better deck from 15 years ago. Meanwhile, the $100 DVD player has the same or better capabilities as the old CD player because the higher volume keeps the price down. This is also why a mass market $300 multichannel AVR is often a better choice for stereo listening than a $300 dedicated stereo receiver, and why many cheap 20 year old turntables that were cranked out in volume back in the day will outperform a more expensive new entry level TT.
For your FLAC question, FLAC is a good format, and more and more receivers and disc players are including USB ports and FLAC compatibility. The big drawback is that FLAC doesn't play well with itunes or apple hardware. ALAC is the apple lossless codec, which works on all apple devices and any device with airplay, and is getting more and more market penetration because of it. FLAC is still ahead for now, though. As far as sound quality, FLAC, ALAC and CD (or an uncompressed WAV copied from the CD for that matter) should all sound exactly the same. You can convert between any lossless format back and forth all day long and never lose fidelity, hence the term lossless.
For your CDR quesion, if a CDR is burned without errors, it will be identical. Really cheap and poorly manufactured CDRs may give you problems with errors that may make the CD unplayable or skippy, but as long as the crappy CDR plays, the music is exactly the same.
post #33 of 73
so even a expensive cd player will skip if some of my cds have a lot of scratches from over the years? I have tried cloths and cleaning fluid before for the scratched cds. some of those products seemed like they made it worse. I heard more skipping with some cleaners at walmart. I have tried the cleaning cd that I put in the player and it says it's clean now. what do you use that helps you? I only have one thing that is apple and that is my iphone. I have all pc computers. I use windows media player and vlc media player. I use another site for mp3 and sometimes amazon.com. in the past I had some free song codes from pepsi bottles and redemmed them on itunes. for some reason itunes always freezed my computer a lot. another issue is I am meeting a guy tomorrow to look at a used rotel power amp and used nad power amp. what do I look for problems wise? I don't know anything about power amps except watch out for one channel being louder then another for problems. I know that I don't need both the nad and rotel since I just bought the nad c326bee but he wants to sell both as a package price.
post #34 of 73
Yes.
Try ripping the scratched up audio CD on a PC using EAC.
This often works when nothing else does. Burn the ripped tracks to a new CD-R. It will probably read perfectly.
post #35 of 73
Yes.
If you knew what was inside many hyper-expensive CD players you would either laugh or cry.
I know of one web article on the web that identified the transport of of one player that was carved from billet aluminum as being the same transport that was used in low-end boom boxes. On balance, this may have been a good technical choice but it is not very impressive in context.
I know of another web article that pulled the cover off of another hyper-expensive player and found that it was the top of a hidey-box that was built around a mass-market player.
Yet another high end player turns out to be a lower end and far less expensive player with different markings and color scheme and maybe a few different parts inside.
post #36 of 73
thanks Arny I will try that. What advice can you give on buying power amps used?
post #37 of 73
arny was one of those high end players that used cheaper parts musical fidelity or worse krell creek audio?
post #38 of 73
Buying power amps used is probably not the bad crap shoot that buying used speakers is. Power amps tend more towards catastrophic failure! So, if they work they probably work.
The best deals in power amps are usually pro audio amps by people like Crown, QSC, Behringer, etc.
post #39 of 73
I don't recall all of the details any more. Besides if I didn't know any dirt about any particular high end player, doesn't mean that there isn't any dirt to be known.
I've done bench tests on dozens of audio players and the performance of sub $100 and even sub $50 players is brilliant. A $50 player of today will match or beat a $500+ player from a decade ago or more on the test bench.
post #40 of 73
the deal is rotel power amp and nad power amp $160.00 for the pair. other people said that is a pretty good deal. he may want to keep his jumpers. how much are jumper cables to buy? Are the jumpers in the nad c326bee probally good enough or need better quality?
post #41 of 73
people try to keep me away from pro amps like crown because they say to much distortion, but you are right Arny they are better deals. you use crown sometimes?
post #42 of 73
These people are clueless.
I use all 3 brands - Crown, QSC, Behringer.
I had some fun a few years back when I had both a Behringer A500 and a Pass Threshold 4E kicking around the house.
Vastly different on the bench, but within their non-clipped performance, its all the same.
post #43 of 73
jdnc when you say cd players are now a specialty because a lot of people listen to mp3s now instead? A lot of my friends and family use mp3s only now.
post #44 of 73
Its not 'CD' vs 'mp3', its 'physical' vs 'digital' distribution. CDs are dead as a distribution medium, the only thing lacking at the moment is a major music store offering downloads in a lossless format.
post #45 of 73
xian, but how come I still see fye music stores at malls and target offering good deals on cds? some people like me still must buy them enough to keep making them.
post #46 of 73
why do people bash it a lot on here then xian? I have seen a lot of love hate debate on flac.
You really should not hang out too much on so called "audiophile" sites. Generally clueless.
How can flac be worse than CD when it is lossless, and you can without problems burn a CD from flac files? I use foobar for ripping and burning - if needed.
I only use the bluray player build into my server to rip cd's to file in flac. About 2000 so far. And transfer of some Lp's..
I used to own denon 1420, micromega stage 2, phillips universal player 933 or whatever that was, a pioneer 59Avi, have built a few using cd rom drive and a China sourced controller that worked perfectly with SPDIF and analogue out from the drive and cost about 75$ in parts - and almost double that in a custom made frontpanel and the 1 ru enclosure. Worked like a charm for years and never was able to hear a difference between that cheapo thingy and the Micromega or the Pioneer.
I do not play Cd's anymore directly.
post #47 of 73
Economic death is not instantaneous.
Digital sales surpassed CD sales in 2011 and the trend has continued
Combined with sales of singles passing sales of albums and you run into a bit of a problem for CDs. They will reach a point where the production volumes just aren't high enough to spread out the cost of manufacturing. .
post #48 of 73
but why do people want mp3 albums? Aren't cds much better sound quality? I have heard friends complain to me that the bass didn 't sound as good as the cd of the same album.
post #49 of 73
xian could cd production die in the next two to three years maybe?
post #50 of 73
mp3 isn't the only lossy format albums are purchased in and as I said, something that is missing right now is the lossless music store, although Apple has made hints at offering lossless versions of stuff via itunes. There is no technical hurdle here, its just a matter of market demand and the market for lossless audio is tiny compared to the entire audio market.
post #51 of 73
Depends on your definition of dead. VHS is dead as a major format that doesn't mean you can't still buy them. Vinyl is dead as a format but you can still get some albums in vinyl. Interestingly vinyl sales have increased recently, thought the top selling vinyl album still had about 18,000 units sold, aka, tiny compared to the market.
CDs will just be relegated to a niche market as have VHS and vinyl. It doesn't help that record store sales declined 76% from 2000 to 2010.
As for Fyes still existing, they may manage to live, for now, but Tower Records, Sam Goody's, Virgin, etc have all gone out of business in the last ten years. The fittest will survive and become specialty shops.
I'm 29, I haven't bought a CD in almost a decade, and those were EPs sold at the door by local musicians. I bet if you split the purchasing habits by generation you'll find that my generation and younger don't even consider purchasing CDs in high enough quantities to matter.
post #52 of 73
I am 31. I miss going to tower records in Nashville tn. I like to go to new York city a few times a year. I went to virgin records once in manhattan. I also miss Sam goody. You are right dye will be gone eventually. I admit I still buy CDs but not as much as I did in my teens and early 20s. I bought Ellie that woman who sings that song lights I forget the last name a few months ago. I buy used CDs sometimes at goodwill. I bought a punk cd called the explosion a month ago. Interesting how you mentioned records. I bought about 15 records in the last two weeks at goodwill. I am going to try and buy some new vinyl albums next time I go to a NYC record shop. I used to buy a lot of local bands ep albums also but usually after the concert.
post #53 of 73
The phone put dye sorry I meant fye.
post #54 of 73
CD players are specialty items because Blu Ray players play CDs and just about anything else. Why get a specialized tool when the generalized tool works at least as well?
post #55 of 73
true arny good point. so a blueray player is going to sound better then a regular cd player if just playing music?
post #56 of 73
I heard the nad and rotel amps today Arny and they sounded good. I bought both. I am extremely happy about owning my first Rotel and also first nad power amp.
post #57 of 73
post #58 of 73
CDs are not a niche format (yet), but hardware components that play *only* CDs are becoming a niche item. CD players are everywhere, most just happen to pay DVDs and/or blu rays as well.
post #59 of 73
No, BD players and CD players very strongly tend to sound identically the same while playing CDs. There has been some scare talk about interference from the video circuits, but I've done a ton of bench tests of DVD and BD players as CD players and they are just fine. DVD and BD players used to be slow on the draw, but that has largely been corrected. That leaves the fact that many low end DVD and BD players are hard to use without an attached video display. Of course you can pick up a little LCD TV for like $100 and overcome that!
post #60 of 73
As far as interference from video circuits goes some players have a pure audio feature to cut off video circuits. Not sure of its utility.
For the most part you can navigate a cd just fine without a display. You still see the song number. It gets hard though when trying to navigate ripped content on an attached hard drive or through the network. Then a screen is a must.
