AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Should I notice a huge difference going from the Denon 1613 to Onkyo 809?
post #1 of 4
I want to possibly go 7.2 one day soon. I have two subs already.
post #2 of 4
No one has followed this upgrade path?
post #3 of 4
Depends on your speakers, and how loud you turn you system up. But overall, probably not that big of a difference.
post #4 of 4
What I'm really wondering is if I would essentially be going backwards since the 1613 is a newer receiver. I do mostly home theater so my system doesn't usually go past the 60% max volume point.
I do know that the 1613 could never give me 7.2 but I don't believe the 809 can eq both subs anyhow. The 809's version of audyssey is a little better but I don't know if that will make a big difference or not.
Thoughts?
