AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › is there a 37" LCD that will fit in a 35" width?
post #1 of 5
I have been trying to find a 37"lcd that will fit within a space that is only 35" wide? Does anyone know of one that might fit?
post #2 of 5
post #3 of 5
post #4 of 5
Just about any 37" wide screen should be less then 35" wide check the 37" model specs at the different vendors web sites. A better idea may be to go to a local BB, Costco, or Wal-Mart and measure the different 37" models. Then you can check the to see if they have side air vents which mean that you would have about 3/4" on each side for ventilation.
post #5 of 5
Thank you.
