AVS › AVS Forum › HDTV › HDTV Recorders › What internal capture card/hd pvr should I use?
post #1 of 2
Hello, I am looking for the true answer to which internal capture card I should use to record my xbox 360 gameplay onto my pc, render and edit it, and post the videos on youtube. I am looking for the best quality I can get under about 130 U.S dollars. I have looked at the Hauppaug Colossus, and the Aver Media game broadcaster HD. please tell me what the best choice out of these two is (or if you have another one that is better than both, and not to much more expensive).
post #2 of 2
Might also ask in the HTPC area. I'd bet they'd recommend the gaming edition of the HD-PVR box from Hauppauge
  Back to Forum: HDTV Recorders
