Basic room layout... The room is 13ft wide (not shown in the layout)
The front speakers are DefTech 8060ST's, each has a 10" sub with 300watt amp built-in. According to DefTech, the subs will go down to 20Hz, I think it's closer to 30Hz.
I have purchased an SVS PC12-PLUS, that will hopefully be here Friday.
This gives me the possibility of having 3 subs hooked up. If I understand correctly, multiple subs help smooth room response.
Given not all the subs are the same, is it worth trying to use them all?
Or would I be better off using the DefTech's speaker level inputs only and trying to dial in just the SVS?
Opinions, suggestions....All are welcome....
Thanks in advance....
Edited by ceh383 - 1/23/13 at 8:13pm
