AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Brand new projector; spots on the screen
post #1 of 3
Hello I just bought a benq W710ST and I've noticed it's putting these two fist sized circles near the top two corners almost like a lense flair or water spot. These are not on the out side of the lense as I have cleaned it with no results, if i turn the focus ring the spots will mostly hold their position but change size. I think it's some internal smudge on the lense or something should I be worried about this, should I send it back on warrantee, have you ever experienced this before?
post #2 of 3
Sounds like dust blobs. Exchange it.
Jason
post #3 of 3
I'm guessing that moisture somehow made it to the backside of the lens. Since its new I would exchange it
Bohanna
