AVS › AVS Forum › Display Devices › Rear Projection Units › KDS60A2000 Help adjusting color
post #1 of 4
I just replaced the LCD panel in this SXRD and need help adjusting the colors. I was in the Service mode and may have made some changes in something that was not correct. Volume was up while in test pattern and I was a little frantic. Anyway the convergence lines look real good and color overall is good, but looking at faces and solid color walls I can see funny lines like when you throw a rock in water.
Look at upper right corner to see the color problem.
If someone could maybe tell me what to change in the Service menu would help. I really feel like that is what happened. I have tried to find a list of the Service menu codes, but cannot.
post #2 of 4
Hi If you can get me the panel service in the service menu area write em down from the beginning to the end i can check it agaist my setting is that something you can copy all the service menu stuff we can help each other out not to many people still have this tv
post #3 of 4
Larry, thanks for the reply. I am not a technician, so I'm not sure what you are asking me to write down.
Is there a certain area that you need to see. If I go through everything it would take me a week to write down.
Hopefully you can be a little more detailed on a particular list/settings that are more related to what the problem is.
I did read something on another post that making me doubt the repair I did. It stated that even though the LCD panel would only go right back with the flat head screws you need to use other screws and enlarge the holes to adjust the panel. So now I'm wondering if that is my whole problem. Since there was no adjustment I just screwed it in place.
Let me know what you need and your thoughts on my repair.
post #4 of 4
Hi thanks for the reply I kinda mess up my tv I don't know if you want to but the setting I really need are in the panel service menu which starts at zero and end in the Lum which is 43 if your adjustment you made looks like it working and everything looks fine I wouldn't worry to much. you say it said to enlarged the hole does it say how much to enlarge cause you can really run into trouble that's a problem I know I screw up if I had to do it. did you try to enlarge the hole ? well let me know how you make out but if you think the repair you made is fine I leave it unless you really have to make it larger
  Back to Forum: Rear Projection Units
