I discovered something about the problem with inverting some 5020/6020s. Some people have reported problems, which may not have been problems in some cases.
When you adjust the pixel convergence, you tell the red pixels to go up. (For instance.) When you invert the screen, up becomes down. However, the pixel alignment is still telling the red pixels to go up. Except that Up is now down, so the alignment adjustment is now telling the pixels to go exactly the wrong direction. So instead of aligning the pixels, the adjustment you had is un-aligning the pixels. Am I making sense? I tested this by not moving the projector, but changed the projection setting back to "Front" from "Front/Ceiling". Sure enough the pixels went out of alignment.
So, if you test a 50020/6020 on a bench before you ceiling mount it, and if you enable "LCD Alignment" while testing on that bench, and then you ceiling mount it, it's going to look like something moved inside because the convergence will now be horrible. The solution is to "reset" the LCD Alignment and start over.
This will also appear to affect focus, as the extreme mis-convergence will effectively expand each pixel, just as if it were out of focus.
Hopefully this information will help some people. I've posted this in multiple places, because I feel it's important for people to know.
Sorry about the title. I meant to say "INVERTED Convergence/Focus problems with Epson 5020/6020 PJs SOLVED.", and now I can't edit it.
Edited by Kirnak - 1/26/13 at 5:04pm
