AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Rythm FV15HP vs SVS PB12 Plus vs SVS SB13 Ultra
post #1 of 10
Hi I am in Australia and I am pretty confident in my choice of getting the rythmik FV15HP. SVS seems to not have the same markup as other products do though which makes me wonder whether I would be better off getting one of their products. It will be mainly be used for electronic music. The pricing is as follows:
1. Rythmik FV15HP $1750.00
2. SVS PB12 Plus $1999.00
3. SVS SB13 Ultra $1999.00
At these prices what would peoples recommendations be?
post #2 of 10
You are making yourself crazy...
post #3 of 10
hahahaha I am already crazy
post #4 of 10
With $2000 I would go with dual HSU VTF15H. Two of these will destroy any of the ones you listed on their own.
post #5 of 10
The OP is located in Australia, two VTF15Hs would cost him more then $2000.
post #6 of 10
I had originally decided on the HSU VTF15H but there is no Australian distributor and I am not interested in shipping them overseas incase of a faulty product.
post #7 of 10
I guess it depends on your definition of destroy... Two VTF15H certainly won't dig deeper than the FV15HP:rolleyes:
post #8 of 10
Yeah, destroy is a pretty bad choice of words. You may get a smoother response and a little more SPL but like you said they won't dig lower.
post #9 of 10
Is the F15 available ? Two of that would be wicked, may not be as strong as the FV15hp, but you would have stereo subs.
post #10 of 10
I am just going to get the one sub now and upgrade to dual subs in the future
