I am hoping someone can help me with my problem. My VT50 connects to my router via wire without a problems. When I try to connect it wirelessly, it identifies the correct SSID, the type and the encryption but no signal strength.
Panasonic support had me reset the TV using power button and then reset the modem. Then my TV connected wirelessly. Later when I turned the TV off and on, it was back to the same problem. I repeated the reset steps and it did not work.
My router is about 10 feet away from the TV. My Panasonic Bluray connects to the router wirelessly. My laptops and smartphone connect to the router without a problem.
My rounter is D-Link D655 and according to Panasonic support ht TV supports it.
Does anyone have any idea how to resolve this problem?
Thanks, Ed
Thanks, Ed
