EDIT: New questions and updated design start in post 17: http://www.avsforum.com/t/1454177/sound-proof-the-ceiling-or-the-floor-above#post_23161020
I am currently working with an architect to design a custom home including a basement home theater. I'm trying to decide on the most cost effective method of controlling noise transmission between the theater and the rest of the house. The house will be built using ICF (Insulated Concrete Forms). For the basement this basically means 2.5" of foam insulation on either side of an 8" concrete core.
In the photo below the hashed walls are the ICF walls basically surrounding the theater on most of three sides with concrete and earth. The other walls will most likely be staggered stud walls.
My biggest concern is sound transmission from the hardwood floors above and to a lesser extent the sound escaping the theater through the ceiling.
I've done my research read about sound proofing ceilings using all kinds of crazy techniques and about using under-laments like Serenity Mat under the floor above.
I can do either or both but which option is the most cost effective? Treat the floor or treat the ceiling?
The more I type the more questions I think of... I better stop for the night.
(This is one of 2 designs I am considering)
Here is a pic of an ICF Form to show the furring strips embedded in the foam. Typically drywall would screw directly to the furring strips in the form.
Edit: Changed the ICF form pic to more clearly show the construction and furring strips.
Edited by jroyv - 4/3/13 at 2:27pm
- Will a floor treatment (like Serenity Mat) help with sound escaping from the theater or just help deaden the foot-falls from above?
- How would using a floor solution by itself compare with the various ceiling sound proofing options found here:
- On a side note to avoid flanking through the side walls I wonder if any decoupling would be provided when attaching drywall to the furring strips in foam insulation of the concrete walls?
- ohhh... I wonder if I could use green glue between the forms and the first layer of drywall? Wonder what green glue would do to the polystyrene of the forms?
First two rows will be theater seats with about 6' 10" to contain the reclining second row. The back seats will not be recliners just comfy gaming seats and at most "overflow" theater seating. I'm ok with them being out of the optimal sound envelope. as long as I can get 7-8 "good seats" in the fist two rows. I do as much xbox and PC gaming in there as I do movie watching.
