Dear Friends,
I am about to update my calibration equipment. As I today run Calman 4 with the X2 meter (basically an eye one display 2 with tables for newer backlight standards) and feel comfortable with this system would like to remain as a Calman user.
My budget is limited, perhaps I can spend some $1000-1400 ex freight. The question is what I should go for… The tools will not be used very often, perhaps once a month but when used it needs it to be pretty reliable. The products I work with are all LCD/LED and currently does not have any auto calibration interface. The pattern source I use today is a WD TV Live media player with AVS HD patterns. (I also have a PS3 available).
The options I consider are listed below. Of course I do not want to spend more money than necessary, but as they have different functions/options I need your help to give me a push to the best choice for my needs. Please also comment if you have any other suggestion or any more information needed.
CalMAN 5 Control with i1 Pro 2 995:-
X-Rite i1Pro 2 Enhanced + CalMAN 5 Control 1290:-
X-Rite i1Pro 2 Enhanced + CalMAN 5 Enthusiast 1390:-
CalMAN 5 Enthusiast with SpectraCal C6 and DPG-2000 Bundle 1399:-
