Hello, I have been watching this forums for quite a while but only now I needed to open a post. I have searched the internet for the past 2 months looking for a solution for my issue but none of them fixed it completely.
Long story short.
I had a Philips HDTV that went to repair after a dead pixel appeared. Meanwhile I decided that the TV was not helping me reaching the desired picture quality and ended up buying a new one.
The new TV is a Samsung Smart TV Series 6300 40inches. However the issues continue.
I want to use my main pc connected to the TV. It will be used for media player and gaming. The PC is using a Nvidia GTX 680 GPU and connected to the the TV by HDMI and monitor by DVI. I have three user accounts on the pc, Normal Dektop usage using monitor, Steam and XBMC.
The setup is working great. The HTPC user account open XBMC as the shell and switches from the monitor to the TV automatically. The Steam user account opens Big Picture mode automatically as shell and switches to the tv automatically to.
So, now that you know my setup, lets go straight to the problem.
I used HD709 patterns to calibrate the TV using XBMC. However the picture doesn't seem quite right. It seems too dark in some areas. Also, using the patterns I could only get all the flash bars to work using Limited Range in the video options of Nvidia Control Panel.
Regarding the Gaming calibration, I learned from the internet that I need to calibrate the color range as Full RGB ( calibrating Black as 0 instead of 16). I tried image patterns, calman PC (without colorimeter) and the picture doesnt seem right. Using Calman PC for calibration I end up with some weird light from the edges on black images. Also, it seems that the picture is not showing correct colors.
So, my questions are:
- How to setup NVIDIA control panel for XBMC video?
- How to correctly calibrate the image for XBMC Video? (please tell me where can I find the right patterns/video/software to do this)
Secondly:
- How to setup NVIDIA control panel for pc general usage / gaming?
- How to calibrate the image for normal / gaming usage? (please tell me where can I find the right patterns/video/software to do this)
I would like to thank you in advance for any advice you guys can give me. I am getting desperate and tired of waiting money without getting the image and experience I deserve. Thank you!
Long story short.
Secondly:
