The XPA-5/XPA-3 is no longer an option. Trying now to figure out how to best utilize the power between my two Denon AVR's.
Current Speakers
Boston VR2: Right Left Mains (Bi-Amp capable)(Recommended Amp Power: 15-150 watts, 93dB sensitivity)
Boston VR20: Center (Recommended Amp Power: 15-250 watts, 91dB sensitivity)
Boston CR77: Wides, Heights Surrounds: (Recommended Amp Power: 15-150 watts, 89dB sensitivity)
Boston CR67: Surround Back: (Recommended Amp Power: 15-150 watts, 89dB sensitivity)
Current Power
Denon AVR-4311CI (140 watt / channel, .05 THD) - Powering everything but heights
Denon AVR-3310CI (130 watt / channel, .05 THD) - Powering heights
No dedicated processing or crossovers
Purpose
To choose the speaker configuration option that provide the best Sound Quality by maximizing available power.
Situation
I intended on selling the 3310 for a used XPA-5 which is no longer available. I do not have the funds to get a new XPA-3/5 and will be keeping the 3310. I may be getting the 4520 to replace the 4311 which will bump output to 150 watt / channel.
My Theory
The thought process behind utilizing the 3310 more is to reduce the load on the 4311(/Possible 4520) by not requiring it to power all 9 channels by itself; with the intent to increase the total usable output of the total system.
Options
A) Continue Powering Heights with 3310, everything else on 4311(/Possible 4520)
B) Bi-Amp Fronts on 3310, power all surrounds with 4311(/Possible 4520)
C) Fronts on 3310 (not bi-amped), power all surrounds with 4311(/Possible 4520)
D) Surrounds & Surround Backs on 3310, rest on 4311(/Possible 4520)
E) Other
Knowing I have to work with the equipment I have, which option would you choose?
Edited by Dreamliner - 1/27/13 at 3:30am
Current Speakers
Current Power
Purpose
Situation
My Theory
Options
E) Other
