I'll be buying a Sony VPL-HW50ES soon. Sorry if this has been posted before, but I'd like to see what post-calibration settings people are using on their Sony VPL-HW50ES projectors, and it hasn't been an easy search. I thought people could benefit from seeing what others are using for settings all on one spot. Please post your Sony VPL-HW50ES settings.
AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Sony VPL-HW50ES settings
Featured Stories
Topics Discussed
Related Forum Threads
- Epson 5020 vs Sony VPL-HW50ES Last post on 4/25/13 at 6:22pm in Digital Hi-End Projectors - $3,000+ USD MSRP
- Magnolia Proposed Setup: Need Some Opinions/Validation Last post on 3/27/13 at 10:07am in Digital Projectors - Under $3,000 USD MSRP
- Have 5 year old Sanyo Z5, how much better are new projectors? Last post on 3/19/13 at 11:01pm in Digital Projectors - Under $3,000 USD MSRP
- BenQ W1070 vs Sony VPL-HW50ES Last post on 3/16/13 at 11:26am in Digital Hi-End Projectors - $3,000+ USD MSRP
- BENQ W1500 Last post on 3/16/13 at 5:46am in Digital Projectors - Under $3,000 USD MSRP
Gear mentioned in this thread:
post #2 of 8
1/25/13 at 12:09pm
- Seegs108
- Trader Feedback: +1
- Dylan Seeger
- offline
- 1,412 Posts. Joined 7/2007
- Select All Posts By This User
Projectors aren't like TV's. There are so many factors that are involved including unit variances, screen color, screen material, screen gain, wall colors, carpet/floor color, bulb life, ect. Sharing settings and using others will not get you closer to a more accurate picture. Each projector is calibrated differently at the factory. Either use the default settings (which are fairly close to accurate out of the box on these units) or buy a colorimeter and do calibration your self. It fairly easy to learn. Check out this thread if you're looking into getting a more accurate picture:
http://www.curtpalme.com/forum/viewtopic.php?t=10457
post #4 of 8
1/25/13 at 8:55pm
- Seegs108
- Dylan Seeger
- offline
A starting point to what? Like I said, the factory settings are pretty close as it is on these units. They will provide a better starting point than any other users settings on here. Getting something closer to D65 using someone else's settings would be pure luck. If you posted what your current room and screen are and someone who had a very similar setup to yours would be the only helpful thing. When I say similar I mean same throw distance, same screen size and same exact screen material, same color walls, same color floors/carpet and roughly the same amount of hours on the bulb. All of those things add a specific color or add an extra (or smaller) amount of light to the screen. Only if the persons setup was VERY similar to that then he could tell you their settings. And the machines would've had to be calibrated very close to each other at the factory to yield great results. The chance of all of this happening are very slim which is why it's best to stick to the factory settings. Using someone else's settings will most likely give you worse results then when you started. Like I said in my previous post; projectors are not like TV's in the slightest.
I'm not trying to be rude. I'm trying to convince you that you're basically wasting your time doing this. If you go through this subforum you'll see there are VERY few threads about calibration and there's a reason why. That reason is what I've just told you. The threads that are on here about calibration mostly talk about the method of calibrating a specific unit. Typically each manufacturer has their own CMS and they each work differently and thus some threads are created to talk about how to access, navigate, point out flaws in the system, and how use them to their fullest. You'll see a lot more people posting charts with their results as opposed to numbers to put into those CMS's because, like I said, each setup has a crap ton of variables that will alter the image and therefore no two CMS settings will give you the same result.
If you aren't going to buy a cheap sensor and try and calibrate yourself what I would do is just go by your eyes and make alterations that look better and better until you're satisfied with the results.
Edited by Seegs108 - 1/25/13 at 9:16pm
post #5 of 8
1/25/13 at 9:09pm
- zombie10k
- Trader Feedback: 0
- JVC RS55 -> 142" HP
- online
- 5,610 Posts. Joined 12/2007
The out of the box settings generally look good, but I've seen some variances in D65 calibration.The last one I calibrated had blue off by quite a bit and needed to be fixed.
The HW50 Gamma tracks very close to 2.2 if you set the menu @ 2.2. Start with this gamma setting and see how you like the PQ.
Also consider turning down the reality creation setting to ~10 or lower (factory is 20). It's set to 50 in 3D and I usually turn it down to ~25.
Thanks for the settings suggestions.
post #7 of 8
1/30/13 at 7:23am
what about the contrast enhancer? do you leave it on (H/M/L) or off?
post #8 of 8
1/30/13 at 8:52am
- wes k
- offline
- 337 Posts. Joined 8/2001
Back to Forum: Digital Hi-End Projectors - $3,000+ USD MSRP
- Sony VPL-HW50ES settings
Currently, there are 1752 Active Users
(329 Members and 1423 Guests)
Recent Discussions
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 10 seconds ago
- › Seaton Sound SubMersive1 48 seconds ago
- › Need projector capable of lighting up huge screen with great picture. 54 seconds ago
- › The Official AVS TiVo "Series4" Premiere topic 2 minutes ago
- › Hey guys...we need a little rallying here... 2 minutes ago
- › Official Sony BDP-S590 and BDP-390 Thread 2 minutes ago
- › The Official Kd-34xbr960 Thread 2 minutes ago
- › Budget subwoofers discussions, opinions and questions thread 2 minutes ago
- › Hot Off The Press: The Latest TV News and Information 2 minutes ago
- › Logitech Debuts Two Harmony Remotes - Ultimate and Smart Control 3 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
